Adaptar 12F83 al 12F629
Meta
Asunto: Adaptar 12F83 al 12F629 MensajePublicado: 23 Ago, 2009 - 02:14
Hola:
¿Alguien puede hechar una mano para adaptar este PIC 12F83 al 12F629/675?
Su código fuente es:
Código:
list      p=12F683        ; list directive to define processor
   #include <p12F683.inc>    ; processor specific variable definitions
   errorlevel  -302          ; suppress message 302 from list file
   __CONFIG   _FCMEN_OFF & _IESO_OFF & _CP_OFF & _CPD_OFF & _BOD_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTOSCIO
;***** VARIABLE DEFINITIONS******************
w_temp        EQU     0x70        ; variable used for context saving
status_temp   EQU     0x71        ; variable used for context saving
FLAGS      EQU      0x20      ;software state register
PULSER      EQU      0x21      ;pulse on counter
DWELLTIMER   EQU      0x22      ;pulse off counter
STATE      EQU      0x23      ;programmed state
BUTTONHOLD   EQU      0x24
FREQR      EQU      0x25      ;frequency value
TEMP1      EQU      0x26
TEMP2      EQU      0x27
PULSEL      EQU      0x28
DWELLTIMEL   EQU      0x29
TEMP5      EQU      0x2A
LEDBLINK   EQU      0x2B
TEMP3      EQU      0x2C
;*******bits in FLAGS register***********
PULSEONR      equ      0
PULSEONL      equ      1
TRIGOUT         equ      2
LEDHI         equ      3
STATECHANGE      equ      4
;*******bits in STATE register***********
RIGHTACTIVE      equ      0
LEFTACTIVE      equ      1
;*********GPIO pin names*****************
LEDL         equ      5
LEDR         equ      4
BUTTONR         equ      2
BUTTONL         equ      3
TRIGGERR      equ      0
TRIGGERL      equ      1
;**********Speed settings: change these to change speed (0x05-0xFF)
FIRERATE1      equ      0x2F
FIRERATE2      equ      0x16
FIRERATE3      equ      0x12
FIRERATE4      equ      0x0F
   ORG     0x000             ; processor reset vector
   goto    main              ; go to beginning of program
   ORG     0x004             ; interrupt vector location
   movwf   w_temp            ; save off current W register contents
   movf   STATUS,w          ; move status register into W register
   movwf   status_temp       ; save off contents of STATUS register
         ;Take a good note here. OSC is left at default 4MHz.
         ; We are running at 1MHz instruction cycle, or 1 micro second
         ;Timer 2 is prescaled 1:4 and compared (PR2) to 250.
         ; we now have hardware interupt that falls every 1ms exactly
         ;within limitation of osctune. Main code is inconsequential.
         ;PULSE and DWELL values control the signals precisely.
         ;All pulse logic is switched within the few microseconds to
         ;service the interupt routine. DO NOT modify the ISR
         ;with any kind of 'wait' or 'loop'. If you want to trigger
         ; timed events do so by setting an open FLAG bit and have the
         ;event done in the main loop.
   btfss   PIR1, TMR2IF      ;timer 2 int happened
   retfie
;**************** LED blinking *********************************************
                        ;Our main routine will turn the flag bit
                        ;LEDON on or off. The 10ms pulse is a duty cycle
                        ;for the code to work with both CG and
                        ;matrix controllers.
BlinkLed
   btfss   FLAGS, LEDHI
   goto   LedLow
   decfsz   LEDBLINK, f         ;if pulse is active, count down 10ms
   goto   RightLED
   movlw   0x0A
   movwf   LEDBLINK
   bcf      FLAGS, LEDHI      ;10ms done, turn off LEDHI bit
   goto   RightLED
LedLow
   decfsz   LEDBLINK, f         ;LEDLO time, count down 10ms
   goto   RightLED
   movlw   0x0A
   movwf   LEDBLINK
   bsf      FLAGS, LEDHI      ;10ms done, turn LEDHI bit on
RightLED
   btfsc   STATE, RIGHTACTIVE   ;is RF on?
   goto   OutputRightLED
   bsf      STATUS, RP0         ;bank 1
   bsf      TRISIO, LEDR      ;tristate LED
   bcf      STATUS, RP0         ;bank 0
   goto   LeftLED
OutputRightLED
   btfsc   FLAGS, LEDHI      ;if ledhi true,
   bsf      GPIO, LEDR         ;turn output hi
   btfss   FLAGS, LEDHI      ;if ledhi flase,
   bcf      GPIO, LEDR         ;turn led output lo
   bcf      TRISIO, LEDR      ;turn output on
LeftLED
   btfsc   STATE, LEFTACTIVE   ;is RF on?
   goto   OutputleftLED
   bsf      TRISIO, LEDL      ;tristate LED
   goto   RightTrigger
OutputleftLED
   bsf      GPIO, LEDL         ;turn output hi
   bcf      GPIO, LEDL         ;turn led output lo
   bcf      TRISIO, LEDL      ;turn output on
;**************** Right trigger logic***************************************
RightTrigger
   goto   ActiveR
   bsf      TRISIO, TRIGGERR   ;output off
   goto   LeftTrigger
ActiveR
   btfss   FLAGS, TRIGOUT      ;controllertype
   bcf      GPIO, TRIGGERR      ;determines
   btfsc   FLAGS, TRIGOUT      ;output state
   bsf      GPIO, TRIGGERR
   btfss   FLAGS, PULSEONR      ;is pulse active?
   goto   OffstateR
   decfsz   PULSER, f         ;if pulse is active, count down 10ms
   goto   LeftTrigger
   bcf      FLAGS, PULSEONR      ;10ms is over, clear flags and
   bsf      TRISIO, TRIGGERR   ;tristate output
   movf   FREQR, w         ;and reset pulse time.
   movwf   PULSER
   goto   LeftTrigger
OffstateR
   decfsz   DWELLTIMER, f      ;count down dwell time to next pulse
   goto   LeftTrigger
   bsf      FLAGS, PULSEONR      ;if dwell is done turn on outputs
   bcf      TRISIO, TRIGGERR   ;and reset pulse time
   movf   FREQR, w         ;from frequency value
   movwf   DWELLTIMER
LeftTrigger
   goto   ActiveL
   bsf      TRISIO, TRIGGERL   ;output off
   goto   EndInterupt
ActiveL
   bcf      GPIO, TRIGGERL      ;determines
   bsf      GPIO, TRIGGERL
   btfss   FLAGS, PULSEONL      ;is pulse active?
   goto   OffstateL
   decfsz   PULSEL, f         ;if pulse is active, count down 10ms
   goto   EndInterupt
   bcf      FLAGS, PULSEONL      ;10ms is over, clear flags and
   bsf      TRISIO, TRIGGERL   ;tristate output
   movwf   PULSEL
   goto   EndInterupt
OffstateL
   decfsz   DWELLTIMEL, f      ;count down dwell time to next pulse
   goto   EndInterupt
   bsf      FLAGS, PULSEONL      ;if dwell is done turn on outputs
   bcf      TRISIO, TRIGGERL   ;and reset pulse time
   movwf   DWELLTIMEL
EndInterupt
   bcf      PIR1, TMR2IF
   movf    status_temp,w     ; retrieve copy of STATUS register
   movwf   STATUS            ; restore pre-isr STATUS register contents
   swapf   w_temp,f
   swapf   w_temp,w          ; restore pre-isr W register contents
   retfie                    ; return from interrupt
;*************************************SUBROUTINES**********************************
Wait10ms
   clrf   TEMP2
   movlw   0x0D
   movwf   TEMP1            ;rough 10ms timer for button debounce.
Loop1
   decfsz   TEMP2, f         ;count down 256*3=768 cycles
   goto   Loop1
   decfsz   TEMP1, f         ;count down 768*13=9986 cycles
   goto   Loop1
   return
ReadEE
   bsf     STATUS    , RP0      ;Bank1
   movlw   0x02
    movwf   EEADR
    bsf     EECON1    , RD      ;start read
    movf    EEDAT    , W
   bcf     STATUS    , RP0      ;Bank0
    return
WriteEE
   bsf     STATUS    , RP0
   movwf   EEDAT
   movlw   0x02
   movwf   EEADR
   bsf      EECON1,WREN       ;Enable write
   bcf      INTCON, GIE       ;Disable INTs
   btfsc   INTCON, GIE       ;See AN576
   goto   $-2
   movlw    0x55             ;Unlock write
   movwf    EECON2
   movlw    0xAA
   movwf    EECON2
   bsf    EECON1, WR          ;Start the write
WaitForEEWrite
   btfsc   EECON1, WR         ;wait for hardware to clear (done writing)
    goto    WaitForEEWrite
   bsf    INTCON, GIE       ;Enable INTS
    return
main
   clrf   GPIO
   clrf   FLAGS            ;clear outputs and code status register
   movlw   0x07
   movwf   CMCON0            ;comparators off
   movlw   0x0F            ;start with 0-3 inputs (ADC read)
   movwf   TRISIO            ;pin 0 & 1 & 5 out, all other inputs
   movlw   0x51            ;Fosc/16, pin 0 analog
   movwf   ANSEL            ;Right trigger is analog input
   movlw   0x04
   movwf   WPU               ;enable week pullups
   bcf      OPTION_REG, 7      ;enable all week pullups
   movlw   0x01            ;Left just, Vdd, channel 0
   movwf   ADCON0            ;module on.
   movlw   0x10
   movwf   TEMP1
Wait4ADC
   decfsz   TEMP1, f
   goto   Wait4ADC         ;acquisition time
   bsf      ADCON0, 1         ;start ADC
   btfsc   ADCON0, 1
   goto   $-1               ;wait for conversion to be done
   movlw   0x40            ;about 0.5V from 2V ref
   subwf   ADRESH, w         ;if f > W, C=1
   btfsc   STATUS, C         ;ie- if trigger > 0.5V, then matrix
   bsf      FLAGS, TRIGOUT      ;matrix config sources (output high)
   movlw   0x0C            ;restore pin IO
   movwf   TRISIO
   clrf   ANSEL            ;all digital now
   movlw   0x0A            ;start with 10ms pulse width
   movwf   LEDBLINK         ;for the LEDs
   movlw   FIRERATE1         ;this will get overwritten,
   movwf   PULSER            ; but start with a default value
   movwf   PULSEL
   movwf   DWELLTIMER
   movwf   DWELLTIMEL
   call   ReadEE            ;get state value
   movwf   STATE
   movlw   0x01
   movwf   T2CON            ;timer 2, prescale 1:4, no postscale
   movlw   0xFA
   movwf   PR2               ;setup 1ms hardware interupt
   bsf      PIE1, TMR2IE      ;enable timer2 interupt
   bsf      T2CON, TMR2ON      ;turn on timer2
   movlw   0xC0
   movwf   INTCON            ;turn on interupts globally
   goto   InitState         ;get first firerate value
;******MAIN LOOP***************
Start
TestLeft
   btfsc   GPIO, BUTTONL
   goto   TestRight         ;Test for left button press
   call   Wait10ms
   btfsc   GPIO, BUTTONL      ;button is down for 10ms
   goto   TestRight
ReleaseLeft
   btfss   GPIO, BUTTONL      ;wait for button release
   goto   ReleaseLeft
   call   Wait10ms
   goto   ReleaseLeft
   movlw   0x02
   xorwf   STATE, f         ;toggle left trigger
   call   WriteEE            ;store state
TestRight
   btfsc   GPIO, BUTTONR
   goto   Start
;   goto   DisplayState      ;Test for right button press
   call   Wait10ms
   btfsc   GPIO, BUTTONR      ;button is down for min 10ms
   goto   Start
;   goto   DisplayState
   movlw   0xC8
   movwf   BUTTONHOLD         ;setup for 2 second hold
First2seconds
   call   Wait10ms
   btfsc   GPIO, BUTTONR      ;button is down for more than 10ms
   goto   ReleaseRight
   decfsz   BUTTONHOLD, f
   goto   First2seconds
   movlw   0xC8
Second2seconds
   call   Wait10ms
   btfsc   GPIO, BUTTONR
   goto   ReleaseRight
   goto   Second2seconds      ;button down for 4 seconds, change firerate
NextState
   movlw   0x40
   addwf   STATE, f         ;change firerate state
InitState                  ;begin test for
   btfsc   STATE, 7         ;state 1 or 2
   goto   State3
   btfsc   STATE, 6
   goto   State2
State1
   movlw   FIRERATE1            ;state 1
   movwf   FREQR
   bcf      STATE, RIGHTACTIVE      ;led off
   movlw   0x0A
   movwf   TEMP3
Loop01
   call   Wait10ms            ;100 ms
   decfsz   TEMP3, f
   goto   Loop01
   bsf      STATE, RIGHTACTIVE      ;led on
   bsf      FLAGS, STATECHANGE      ;notify a state change
   goto   ReleaseRight
State2
   movlw   FIRERATE2         ;state 2
   movwf   FREQR
   bcf      STATE, RIGHTACTIVE      ;blink twice, led off
   movlw   0x0A
   movwf   TEMP3
Loop02
   decfsz   TEMP3, f
   goto   Loop02
   movlw   0x0A
   movwf   TEMP3
Loop03
   decfsz   TEMP3, f
   goto   Loop03
   movlw   0x0A
   movwf   TEMP3
Loop04
   decfsz   TEMP3, f
   goto   Loop04
   goto   ReleaseRight
State3
   btfsc   STATE, 6
   goto   State4
   movlw   FIRERATE3         ;state 3
   movwf   FREQR
   bcf      STATE, RIGHTACTIVE      ;blink 3 times, led off
   movlw   0x0A
   movwf   TEMP3
Loop05
   decfsz   TEMP3, f
   goto   Loop05
   movlw   0x0A
   movwf   TEMP3
Loop06
   decfsz   TEMP3, f
   goto   Loop06
   movlw   0x0A
   movwf   TEMP3
Loop07
   decfsz   TEMP3, f
   goto   Loop07
   movlw   0x0A
   movwf   TEMP3
Loop08
   decfsz   TEMP3, f
   goto   Loop08
   movlw   0x0A
   movwf   TEMP3
Loop09
   decfsz   TEMP3, f
   goto   Loop09
   goto   ReleaseRight
State4
   movlw   FIRERATE4         ;state 4, 22ms cycle
   movwf   FREQR
   bcf      STATE, RIGHTACTIVE      ;blink 4 times, led off
   movlw   0x0A
   movwf   TEMP3
Loop10
   decfsz   TEMP3, f
   goto   Loop10
   movlw   0x0A
   movwf   TEMP3
Loop11
   decfsz   TEMP3, f
   goto   Loop11
   movlw   0x0A
   movwf   TEMP3
Loop12
   decfsz   TEMP3, f
   goto   Loop12
   movlw   0x0A
   movwf   TEMP3
Loop13
   decfsz   TEMP3, f
   goto   Loop13
   movlw   0x0A
   movwf   TEMP3
Loop14
   decfsz   TEMP3, f
   goto   Loop14
   movlw   0x0A
   movwf   TEMP3
Loop15
   decfsz   TEMP3, f
   goto   Loop15
   movlw   0x0A
   movwf   TEMP3
Loop16
   decfsz   TEMP3, f
   goto   Loop16
ReleaseRight
   btfss   GPIO, BUTTONR      ;wait for button release
   goto   ReleaseRight
   call   Wait10ms
   goto   ReleaseRight
   btfsc   FLAGS, STATECHANGE   ;test for button tap or state change
   goto   Continue01
   movlw   0x01
   xorwf   STATE, f         ;toggle left trigger if button tap
Continue01
   bcf      FLAGS, STATECHANGE
   goto   Start
; initialize eeprom locations
   ORG   0x2100
   DE   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07
   END                       ; directive 'end of program'
Saludo.
alef
Asunto:  MensajePublicado: 23 Ago, 2009 - 03:59
Proba cambiando esta linea:
por esta otra:
movwf CMCON ;comparators off
Igual los pic no son iguales eh el 12f683 tiene varias mejoras que si tu programa las usa no te va a andar
Meta
Asunto:  MensajePublicado: 23 Ago, 2009 - 08:12
¿CMCON0 por CMCON?
